Old 07-30-2007, 03:09 PM   #1
toilet problems...
A friend of mine needs your assistance. He lives on the top/second floor of his condo and his toilet wont flush right. He says the toilet spins the water and doesnt do anything. He has tried plunging, 3' auger, draino gel, muriatic acid, and pressurized water device. He said while trying those the toiliet would occasionally flush right but then he would try again and back to spinning water. Any clues? Thanks
sflamedic is offline   Reply With Quote
Old 07-30-2007, 03:14 PM   #2
toilet problems...
There may be a few reasons.... but if the toilet is the only problem in all the plumbing devices... all other devices like sink/bath tub...etc. works very well... then I would think the problem will be the toilet seat or its installation ... some toilet seat have too little exhaused hole causling clogging easily or bad design or damage internal surface...etc..... may need to change for a better quality toilet... why I said that... happened to me few months ago... and now everything works so well after I changed the toilet...
KUIPORNG is offline   Reply With Quote
Old 07-30-2007, 05:54 PM   #3
toilet problems...
So when the water just spins, does it overflow? Or does the water level rise, then drain, but not flow out fast enough?
I'm no pro plumber, but my understanding is that toilets work based on siphon action, that means the escaping water creates a vacuum/suction to pull the water/waste through quickly. If it's flowing very slowly, then something is slowing the suction effect. Clogged pipe or improper venting may cause this and this problem may not be noticed in the other fixture drain lines.
slakker is offline   Reply With Quote
Old 07-31-2007, 11:15 AM   #4
toilet problems...
I was guessing the vent, too.
Jeekinz is offline   Reply With Quote
More On This Topic
People are now living to be in their upper eighties, and beyond. This rise in the senior population is bringing the need for safe, accessible bathrooms to the foreground. No one wants to think their elder parents are facing hygiene hardships. Many... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
How to Unclog a Toilet
How to Unclog a Toilet by Expert Village
We have a toilet that's not flushing, or not flushing very well. What we want to find out is, is the problem in the toilet drain, or is the problem in the toilet tank delivering the water to the bowl? So what we do, we have the patented Gilbert's... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
Chemical toilets are located in areas such as airplanes, recreational vehicles and boats. They also offer a sanitary solution when a conventional toilet is not practical. There are a few guidelines to follow when you decide to use a chemical toilet to... Read More »
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Raised toilet flush problems ricgail Plumbing 2 11-17-2006 07:06 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
