Toilet Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2009, 07:16 AM   #1
toilet problem
why does my toilet gurgle when the dish washer is in use as well as the shower and the sinks. and why after using these items i am unable to flush the toilet up to 1 hour after use.
ruben williams is offline   Reply With Quote
Old 02-20-2009, 09:07 AM   #2
plumbing contractor
PLUMBINGITALL's Avatar
sounds like you have a clogged line or a stopped up vent
PLUMBINGITALL is offline   Reply With Quote
Old 02-20-2009, 11:19 AM   #3
Normally, this is a vent problem. Drain lines need air to operate properly. The vent supplies this air. The vent pipe is the one you see going out of your roof. Each drain in the house is connected to this pipe. For ease of understanding, place a drinking straw into a glass of water. Put your finger over the end of the straw and lift the straw up. Water will stay in the straw until you remove your finger. In the winter, spiderwebs can collect condensate and freeze, birds will often nest there or an animal can fall down, and clog it. You need to go onto the roof (if safe) and look down the pipe with a flashlight. If you can see a clog, remove all you can by hand and then flush with a garden hose.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-20-2009, 03:17 PM   #4
toilet problem
Thank you gantlemen i will call in a plumber to get it fixed.
Now that i know what might be the problem.
I know if i call in a plumber they can not tell me it is with in the drain line which i already had replaced.
Once again thank you Ruben
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 11:42 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
