Toilet Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-30-2008, 07:00 AM   #1
Toilet Problem
I need to flush my toilet about 6 times before the water comes down from the cistern. Sometimes it flushes first time but most of the time it takes ages.
I've checked the mechanism and it all seems attached could it be a blockage in my pipes or something?
Cheers
conn15 is offline   Reply With Quote
Old 08-30-2008, 07:20 AM   #2
Whatamess
What supplies the water to your cistern, Rain? sounds like a blockage. Turn the water off, disconnect the supply line from the fill valve and using a bucket open the valve and see what kind of flow you have. If the flow is good the fill valve is stopped up.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 01:10 AM
Toilet cistern problem pmasalawala@talk21.com Plumbing 5 08-07-2007 03:38 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 05:05 PM
