Toilet Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2012, 11:33 PM   #1
Rewards Points: 89
Toilet problem
Okay looking for some advice before I just end up having to buy a new toilet.
Toilet is 20 years old and I just recently replaced all of the parts inside the tank. Doing this didn't solve the problem so I only have a few more things to try.
What happens: The toilet flushes but seems to run out of steam and doesn't properly discard what's in the bowl. Normally a bunch of shredded toilet paper returns to the bowl after the flush is complete.
I attempted to run a cheap auger down and it didn't help but I'm not sure it did a whole lot of good. Next thing I'm going to try is to run a garden hose down the vent pipe and see what that accomplishes.
Any suggestions before my wife kills me?
REXAMUS is offline   Reply With Quote
Old 06-20-2012, 11:51 PM   #2
Did you make sure that the little holes under the rim and the smaller one at the bottom, siphon jet, are clean and clear?
VIPlumber is offline   Reply With Quote
Old 06-21-2012, 12:17 AM   #3
Rewards Points: 89
Little holes were cleaned..smaller one at the bottom? siphon jet? Not sure about those.
Old 06-21-2012, 12:27 AM   #4
It should be located where the little brush head is.
Old 06-21-2012, 12:29 AM   #5
Rewards Points: 89
No hole down there on my antique toilet!
Toilet flush lever problem diyrocks General DIY Discussions 20 12-09-2016 09:12 PM
Slow/overflowing toilet mchouserenter Plumbing 2 08-07-2011 09:27 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
toilet problem Jason & Amanda Plumbing 8 10-27-2008 07:42 PM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 11:42 AM
