Toilet Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2007, 09:35 AM   #1
Toilet Problem
so i am lower than a novice but i want to fix this myself =)
after a flush the water level in the bowel begins to VERY VERY slowly raises. it takes about 2-3 hours to reach the top of the overflow tube and once it does there is a mini-flush. before i go taking everything apart anyone have an idea what the problem is?
thanks
sloane
Sloane is offline   Reply With Quote
Old 12-13-2007, 10:12 AM   #2
47_47's Avatar
Rewards Points: 58
Bad fill valve or if it an older style a bad float.
47_47 is offline   Reply With Quote
Old 12-13-2007, 10:25 AM   #3
so i should probably replace the whole floating ballcock and the tube it is attached to right?
Old 12-13-2007, 10:27 AM   #4
Oldguy
Rehabber's Avatar
If it's an older toilet, some of the internal passages may be clogged with calcium deposits. If that is the case you're best off replacing it.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-13-2007, 11:24 AM   #5
Since you mentioned the overflow tube, I assume you are referring to the tank and not the toilet bowl. For less than $10 you can purchase a Fluidmaster 400A fill-valve. The instructions are vey good and it is an easy fix. It will also eliminate the ball.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
toilet bowl water level problem? darsunt Plumbing 3 08-26-2007 01:10 AM
Toilet cistern problem pmasalawala@talk21.com Plumbing 5 08-07-2007 03:38 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 05:05 PM
toilet rough-in problem christinalee Plumbing 1 12-31-2005 05:37 PM
