Toilet Plumbing Under Basement Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2012, 06:32 PM   #1
Toilet plumbing under basement slab
I want to put a 3" PVC toilet drain on existing cast iron 4" drain under slab in basement. I will use fernco no coupling. As in the pic it will be located about 6" from the existing cast iron bend. That bend only has an 1/8" slope or a little more. Is that enough slope?
John Callahan is offline   Reply With Quote
Old 05-31-2012, 06:37 PM   #2
Rewards Points: 13,270
Looks like you have the wye backwards.
Old 05-31-2012, 07:02 PM   #3
That soil stack goes through the foundation and outside. The wye is in the direction of the slope...is'nt that correct?
Old 05-31-2012, 07:07 PM   #4
Rewards Points: 582
hey john that should be right I see the fall on pipe in picture just make sure the stack is existing house there..what is up line fron your wye........another way is cut it and see I think your fine..
Old 05-31-2012, 07:18 PM   #5
Installing Toilet/Sink/Shower and there is an existing washer drain at the front.
Thanks so much!
Tags
basment
How to design plumbing drainage in basement sonicsmooth Plumbing 0 02-02-2011 02:55 AM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
Rough underground plumbing for basement bathroom JTK Plumbing 1 07-23-2008 09:30 AM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 04:20 PM
