Toilet Plumbing Question.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2008, 08:20 PM   #1
Toilet Plumbing question..
Ok I have some toilets from back in the early 80's so the older style tank setup.. My question is can I upgrade the tank guts to the new style stuff?
My tank setup looks very close to this....
I was looking at one of the complete kits that come in a green box at Lowes and costs around $40..
okcjeeper is offline   Reply With Quote
Old 11-03-2008, 07:24 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Unless the toilet tank is leaking between the tank and the base, all that you should need to replace are the fill valve and flapper. Get a Fluidmaster 400A fill valve with a flapper (bubble pack). It comes with easy illustrated installation instructions.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-03-2008, 04:45 PM   #3
Good deal..I'll head to Lowes and grab one..Will make fixing the nasty noise the fill valve makes..Thanks for the help.
Old 11-03-2008, 06:36 PM   #4
Man of many hats
wrangler's Avatar
Rewards Points: 354
Not only should it eliminate the noise, but also the neccessity for that brick you have in there!
Man of many hats
wrangler is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
plumbing stack question vinman Plumbing 2 08-03-2006 06:02 PM
