Old 01-07-2010, 03:15 PM   #1
Toilet plumbing layout
i am wondering what the best layout for my toilet plumbing and vent layout. i have a crawl space about 5 ft tall and the main line i am connecting into is about a foot off the ground and about 12 feet away. should i drop straight down about 3 feet before my long bend 90 deg so i have a nice shallow taper to my sewer line which i heard allows better waste movement or should i angle it right from the toilet. and where would be the best place for my vent. i was thinking of dropping straight down and having a cleanout and vent behind the bottom bend but wasn't sure if there is a long bend 90 tee so i could do that. also right next to the toilet will be a shower with a 2" drain that will also tee into the 3" line from the toilet and i am not sure if the vent for the tiolet will be enough for the shower also or should i vent that just after the s trap under the house. any help would be great. my head is getting sore banging it against the wall.
akbeard is offline   Reply With Quote
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
New toilet plumbing MICHAEL55 Plumbing 2 05-15-2009 07:14 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
