Toilet Plumbing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-22-2012, 08:31 PM   #1
Angry
Toilet plumbing issue
Installing new floor around toilet, problem of old plastic flange glued into drain pipe. Help!!
JohnnyLion82 is offline   Reply With Quote
Old 09-22-2012, 08:42 PM   #2
Rewards Points: 13,712
Cut the piece to size then cut it in half right where the middle of the flange is so you can install one side at a time, may have to add some blocking where the cut is.
An even better way is to go under the floor and cut the PVC pipe. Install the floor then use a hubless connector to reconnect the pipe.
Old 09-22-2012, 09:42 PM   #3
OP, is your problem:
1. with a cracked/deformed flange? or
2. with your toilet flange that will be lower than your new floor?
allthumbsdiy is offline   Reply With Quote
Old 09-23-2012, 08:13 AM   #4
Reply to Allthumbs
The old flange had a metal ring around it that rusted and broke off leaving the plastic part still glued into the drain pipe.
Old 09-23-2012, 08:26 AM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 672
Go look at this thread, it might help you-
Need to replace this toilet flange, how? And where to find a new 1
Old 09-23-2012, 08:27 AM   #6
Then you going to have to cut the pipe slide out the flange and tail piece and replace.
Old 09-26-2012, 03:12 PM   #7
New info on toilet flange problem
My sink and toilet drain are connected by a t joint? Is there anyway of getting around replacing that??
Old 09-26-2012, 05:52 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
a T or a Y
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-26-2012, 06:32 PM   #9
Plumber
Rewards Points: 672
Did you scan this thread for ideas?
Or perhaps this will work
http://www.ipscorp.com/plumbing/wate...es/pushnrepair
Old 09-26-2012, 11:03 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Pictures?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Plumbing modification for toilet relocation BigJimmy Plumbing 1 07-30-2012 10:39 PM
perplexing plumbing issue ripper2 Plumbing 21 08-03-2010 07:34 PM
septic issue? musty smell in house, and toilet won't flush karen71 Plumbing 5 02-18-2010 03:14 PM
Toilet riser issue JJ2790 Plumbing 4 02-15-2010 10:31 AM
Toilet Plumbing question.. okcjeeper Plumbing 3 11-03-2008 06:36 PM
