-   -   Toilet plumbing issue (http://www.diychatroom.com/f7/toilet-plumbing-issue-157667/)
JohnnyLion82 09-22-2012 08:31 PM
Installing new floor around toilet, problem of old plastic flange glued into drain pipe. Help!!
joecaption 09-22-2012 08:42 PM
Cut the piece to size then cut it in half right where the middle of the flange is so you can install one side at a time, may have to add some blocking where the cut is.
An even better way is to go under the floor and cut the PVC pipe. Install the floor then use a hubless connector to reconnect the pipe.
allthumbsdiy 09-22-2012 09:42 PM
OP, is your problem:
1. with a cracked/deformed flange? or
2. with your toilet flange that will be lower than your new floor?
JohnnyLion82 09-23-2012 08:13 AM
Reply to Allthumbs
The old flange had a metal ring around it that rusted and broke off leaving the plastic part still glued into the drain pipe.
TheEplumber 09-23-2012 08:26 AM
199 Attachment(s)
Go look at this thread, it might help you-
http://www.diychatroom.com/f7/need-r...=toilet+flange
joecaption 09-23-2012 08:27 AM
Then you going to have to cut the pipe slide out the flange and tail piece and replace.
JohnnyLion82 09-26-2012 03:12 PM
New info on toilet flange problem
My sink and toilet drain are connected by a t joint? Is there anyway of getting around replacing that??
GBrackins 09-26-2012 05:52 PM
a T or a Y
TheEplumber 09-26-2012 06:32 PM
199 Attachment(s)
Did you scan this thread for ideas?
Or perhaps this will work
http://www.ipscorp.com/plumbing/wate...es/pushnrepair
plummen 09-26-2012 11:03 PM
Pictures? :whistling2:
