Toilet Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2008, 07:23 AM   #1
Rewards Points: 264
Toilet Placement
I thought I remember reading in a thread way back when that a toilet had to be a certain distance from an exterior wall, and now I can't find that thread. Is that correct? I can't think why it would be an issue but I wanted to check; its always so much easier to just do something right the first time
moneymgmt is offline   Reply With Quote
Old 02-11-2008, 08:33 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The usual distance from a finished wall is 12" on center of a toilet flange. There also are minimum distances allowed from each side and front for other walls, sink bases, etc. Check with your Building Inspection Department for local code. You need a permit and inspections from them anyway.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-11-2008, 08:54 AM   #3
Rewards Points: 264
"The usual distance from a finished wall is 12" on center..."
Maybe that's what I recall reading. The distance isn't really my question, its more if it could be placed on an exterior wall vs an interior wall.... don't know why I thought it might have been an issue. Thanks!
Old 02-11-2008, 10:42 AM   #4
Long-Time DIYer
Of course plumbing may be placed on an exterior wall. It just has to be more carefully insulated to keep the supply pipes from freezing.
Sorry that I misunderstood your question.
Mike
Old 02-11-2008, 11:04 AM   #5
I have not seen a code stating you could not install a toilet on an outside wall, but most bathrooms are not set up in a manner to make this feasable. Normally, this would take up unnecessary room. As Mike said, freezing would be the only downfall for this installation. Actually, since the flange would be approximately 12" from the outside wall, even this is not a big deal unless your drain piping is "in" the outside wall. Most codes I have worked under state that there must be 15" from the center of the toilet (side to side) to any wall or cabinet.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 02-11-2008, 11:32 AM   #6
Rewards Points: 264
Thanks, I appreciate the advice. I don't know where the idea got into my head but I just wanted to verify that I could indeed put it on an outside wall. We just framed in a bathroom upstairs and are working on how to lay it out. No doubt it is tiny, and with a bungalo ceiling it makes it even more crammed. The door had to go in a certain spot, therefore the shower had to go in a certain spot, now we're toying with the toilet and sink placement. I'm sure threads will follow in the future about other joys of being a DIY'er.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Any sort of footing material to put under toilet? BradG Plumbing 3 12-18-2007 08:59 AM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 01:34 AM
