Toilet Pipe Rises Above New Tile Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2010, 03:05 PM   #1
Toilet pipe rises above new tile floor
I recently removed the old flooring(about 1 inch), down to the sub floor and then installed hardie backer and tile. Now the pipe sticks slightly abouve the tile, which causes the toilet to rock slightly and not seal. Any ideas?
jmsmith251 is offline   Reply With Quote
Old 10-24-2010, 03:19 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
What type of flange/pipe is it? What material? PVC?
What is down below? Basement? Concrete?
DM
Old 10-24-2010, 09:16 PM   #3
Residential Renovations
Tattoo's Avatar
You are probably not going to meet the proper deflection rates for tile with only the sub floor and some hardi as the hardi does not add any support at all. Keep an eye on your tiles for cracking or grout cracking..... You may just be pulling them back up in the near furure to add that extra sub flooring back down and then you toilet drain will be to short.
Tattoo is offline   Reply With Quote
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 06:33 PM
Tile, Radiant Floor, Avoiding screwing into the water lines Cecosugi Flooring 10 01-28-2010 08:00 PM
toilet flange connection to lead soil pipe rd115 Plumbing 1 11-22-2009 06:37 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
