12-21-2012, 02:32 PM
#1
toilet pipe
hello, i am installing my toilet and the ground pipe is 3 7/8 inch and all i can find is 3 or 4 inch flange's. from what i hear the flange is suppose to go inside the pipe so the 4 inch is too big and the 3 is too small. anybody come across this before?
12-21-2012, 02:51 PM
#2
toilet pipe
A 4-inch flange should work just fine.
12-21-2012, 02:53 PM
#3
call me E
toilet pipe
Seems to be an odd size- can you upload a picture? What is the pipe made of-plastic, cast iron, lead, copper?
12-21-2012, 02:57 PM
#4
toilet pipe
made of plastic
12-21-2012, 03:01 PM
#5
toilet pipe
but how do i get a 4inch flange into the 3 7/8 inch pipe? i also thought maybe putting the flange on the outside of the pipe but wont it leak?
12-21-2012, 03:23 PM
#6
Super Moderator
toilet pipe
You will be priming and gluing this---outside flanges are always the first choice
There are several 'plastics' used for pipe--all use a special glue (solvent) describe the pipe,please---
12-21-2012, 06:41 PM
#7
toilet pipe
you should be able to glue a 3" hub closet flange into the 4" pipe..   ben sr
12-21-2012, 07:35 PM
#8
Roofmaster
toilet pipe
Maybe the pipe is not DWV?
" A lot of men build things, and a lot of things fall down "
12-21-2012, 08:33 PM
#9
toilet pipe
it really should not matter if it plastic and measured 3 7/8 id a 3"hub flange measures 3 7/8 od....good point though...ben sr
12-21-2012, 08:43 PM
#10
call me E
toilet pipe
I thought you guys were nuts - I could have sworn I read 3 7/8 O.D. somewhere
12-21-2012, 09:00 PM
#11
toilet pipe
no your not nuts ..well i really can't say for sure don't know you that well    ...but 4"plastic abs measures 3 7/8 id and a 3"hub closet flange will glue right into it..we do it all the time... of course this is pvc same
12-21-2012, 09:05 PM
#12
call me E
toilet pipe
I didn't say I was nuts- I was questioning you're sanity because I read too much into the thread
Do you use 4x3 90's or pipe the whole line in 4"
12-21-2012, 09:11 PM
#13
toilet pipe
4" whole line because after tile we cut off 4" flush to tile glue and hammer drill 3"hub flange into 4"
12-22-2012, 11:17 AM
#14
toilet pipe
It is a 4" abs riser in concrete. Is there a flange gasket that goes inside or do I have to bust concrete to get on outside gasket?
12-22-2012, 11:28 AM
#15
call me E
toilet pipe
Your answer has been posted already- please reread
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
