-   -   toilet pipe (http://www.diychatroom.com/f7/toilet-pipe-167076/)
tanpat 12-21-2012 01:32 PM
toilet pipe
hello, i am installing my toilet and the ground pipe is 3 7/8 inch and all i can find is 3 or 4 inch flange's. from what i hear the flange is suppose to go inside the pipe so the 4 inch is too big and the 3 is too small. anybody come across this before?
md2lgyk 12-21-2012 01:51 PM
A 4-inch flange should work just fine.
TheEplumber 12-21-2012 01:53 PM
199 Attachment(s)
Seems to be an odd size- can you upload a picture? What is the pipe made of-plastic, cast iron, lead, copper?
tanpat 12-21-2012 01:57 PM
made of plastic
tanpat 12-21-2012 02:01 PM
but how do i get a 4inch flange into the 3 7/8 inch pipe? i also thought maybe putting the flange on the outside of the pipe but wont it leak?
oh'mike 12-21-2012 02:23 PM
You will be priming and gluing this---outside flanges are always the first choice
There are several 'plastics' used for pipe--all use a special glue (solvent) describe the pipe,please---
ben's plumbing 12-21-2012 05:41 PM
you should be able to glue a 3" hub closet flange into the 4" pipe..:yes::yes:ben sr
jagans 12-21-2012 06:35 PM
Maybe the pipe is not DWV?
ben's plumbing 12-21-2012 07:33 PM
it really should not matter if it plastic and measured 3 7/8 id a 3"hub flange measures 3 7/8 od....good point though...ben sr
TheEplumber 12-21-2012 07:43 PM
199 Attachment(s)
I thought you guys were nuts - I could have sworn I read 3 7/8 O.D. somewhere :eek:
ben's plumbing 12-21-2012 08:00 PM
1 Attachment(s)
no your not nuts ..well i really can't say for sure don't know you that well:laughing::laughing::laughing:...but 4"plastic abs measures 3 7/8 id and a 3"hub closet flange will glue right into it..we do it all the time... of course this is pvc same
TheEplumber 12-21-2012 08:05 PM
199 Attachment(s)
I didn't say I was nuts- I was questioning you're sanity because I read too much into the thread :laughing::wink:
Do you use 4x3 90's or pipe the whole line in 4"
ben's plumbing 12-21-2012 08:11 PM
4" whole line because after tile we cut off 4" flush to tile glue and hammer drill 3"hub flange into 4"
tanpat 12-22-2012 10:17 AM
It is a 4" abs riser in concrete. Is there a flange gasket that goes inside or do I have to bust concrete to get on outside gasket?
TheEplumber 12-22-2012 10:28 AM
199 Attachment(s)
Your answer has been posted already- please reread
