Toilet Overflow After Water Shut Off - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 09:47 PM   #1
Toilet overflow after water shut off
If a toilet clogs and can not be cleared with a plunger and overflows with clean water after the water has been shut off to the toilet is this a overflow problem? I am on the third floor and the toilet clogged, could not clear with plunging, water reseded almost completely from tank. The next morning it had filled again with clean water overflowing.the tank????
Gracie George is offline   Reply With Quote
Old 06-23-2011, 10:06 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is more wrong with that toilet than just a clog. The tank has an overflow but if the main drain is clogged then so is the tank overflow.
The tank can't overflow if the water is shut off.
The bowl can overflow (one time) if the water is shut off, the drain is clogged, and you flush the sucker just one more time to see what will happen.
You need a plumber not a DIY Forum.
XXX
Old 06-23-2011, 10:07 PM   #3
mam, are you calling the bowl your tank? budro
buddy builder is offline   Reply With Quote
Old 06-24-2011, 12:38 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The tank can never overflow.
It will always flow out into the bowl and the bowl will overflow.
Your bowl is clogged. Call a pro if you can't get it with a plunger. They have the right tool.
I do have to admit most people don't know how to use a plunger properly. I've gone into houses and used their plunger for them, and didn't have to dirty up my toilet auger.
Journeyman Plumber
Old 06-24-2011, 07:33 AM   #5
Plumb or Die!
Think we need more info.
plumber666 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Main water valve in condo shut off, but neighbors can still hear water running through pipes. cookiebird87 Plumbing 1 12-01-2010 04:43 PM
Icemaker water wont shut off bigskyjen Appliances 2 05-19-2010 11:30 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
