Toilet Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2014, 03:28 AM   #1
Toilet overflow
I have a cistern which keeps filling and overflowing to outside pipe. I have tightened screw at opposite end as far as it will go clockwise and no change- any suggestions
My ballcock is a plastic type so bending the arm isn't an option
Janasshe is offline   Reply With Quote
Old 08-05-2014, 05:14 AM   #2
DIY staff
Rewards Points: 7,174
Welcome to the forum---
There are many kinds if toilet flush valves---the one you describe is adjusted as you have done---if turning the screw in all the way on the end of the ball cock--then the valve itself has issues---those can be rebuilt---however a new flush valve is very inexpensive-about $10.00 USD--so most folks simply buy a new valve.
Replacement is simple--
jmon (08-05-2014)
Old 08-05-2014, 10:06 AM   #3
toilet
thank you i will purhase a new one and hopefully that will work
water issues today - toilet overflow BigV Plumbing 57 07-23-2013 06:34 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet overflow after water shut off Gracie George Plumbing 4 06-24-2011 07:33 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
