Toilet Offset 11.5" - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 07:01 AM   #1
Rewards Points: 77
Toilet offset 11.5"
Hey everyone.
In my basement, it turns out that the rear wall to centre of toilet stack is 11.5". Do you think that I can get away with a toilet that's 12" offset? I'm not too concerned if the tank with have to be a little tilted.
Thanks to all who reply!
mlijoi is offline   Reply With Quote
Old 01-24-2013, 07:25 AM   #2
DIY staff
Rewards Points: 7,174
most will fit just fine----check at the store----
Old 01-24-2013, 07:34 AM   #3
Rewards Points: 77
By checking at the store would it be taking a measurement? And if so from where to where? Most of them on the boxes say 12" offset.
Old 01-24-2013, 07:50 AM   #4
Rewards Points: 582
all most all 12"rough ins will fit in 11 1/2 ..tank will probley just touch wall...ben sr
Old 01-24-2013, 07:54 AM   #5
Rewards Points: 22
The mounting holes will be center of the opening, so you will want to measure from the center of the mounting holes to the farthest rear point of the toilet, which will typically be the lid; anything less than the distance that you have from the center of your opening to your wall will work. When the margins are tighter, as in your case, I have found a framing square to be useful for a quick confirmation; stand it on edge next to the display unit, and it's pretty easy to confirm your dimensions.
Old 01-24-2013, 10:31 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you 11.5" to the rough wall, or the sheetrock?
Journeyman Plumber
Old 01-24-2013, 10:34 AM   #7
Roofmaster
Rewards Points: 2,172
Keep in mind that they are talking about the surface of the finished wall. Souix Chief makes offset flanges also, if that will work in your case.
Old 01-24-2013, 12:42 PM   #8
Rewards Points: 77
Thanks to all the fine posts!
It's 11.5" from sheetrock. I REALLY want to avoid using an offset flange! Afterall, it's onle 1/2"
The Following 2 Users Say Thank You to mlijoi For This Useful Post:
ben's plumbing (01-24-2013), oh'mike (01-24-2013)
Old 01-24-2013, 02:24 PM   #9
Rewards Points: 3,130
Some toilets (like mine) have an adjustment for the position of the tank. Gives you a couple of inches to play with.
Old 01-24-2013, 03:01 PM   #10
Rewards Points: 582
it should work..ben sr
Old 01-24-2013, 05:18 PM   #11
Plumber
If a 12" toilet wont fit, you can always get a 10" .
DidIDoThat is offline   Reply With Quote
Old 01-26-2013, 12:35 AM   #12
Rewards Points: 370
but you may need to go to a real plumbing supply house. A couple of years ago, I got a 10" from Home Cheapo. Last year, I needed one for the upstairs. Home Cheapo no longer had them and I was told no one made a 10". A call to my pipe supplier and I had a new 10" delivered to the shop.
fireguy is offline   Reply With Quote
Old 01-26-2013, 12:38 AM   #13
skk
12" toilet will fit in 11.5"...just did one.
and as for 10" toilets - they are more expensive and rare.
skk is offline   Reply With Quote
The Following 2 Users Say Thank You to skk For This Useful Post:
ben's plumbing (01-26-2013), oh'mike (01-26-2013)
would it be OK to use two 45 street elbows to offset toilet installation SciGuy Plumbing 3 10-18-2012 12:49 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Offset toilet flange installed correct? acerunner Plumbing 17 06-29-2011 09:03 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
