Toilet Off-Set Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2007, 04:15 PM   #1
Hi there, are toilet off-set flanges frowned upon? Do they have a reputation to give problems? My toilet in the basement sits about 4 feet from a waste basin that pumps into the septic tank...that short traveling distance means I could use a 6 L toilet vs a 13 L, right??
Thanks..
flyultralite is offline   Reply With Quote
Old 12-04-2007, 07:25 PM   #2
Send a message via AIM to Marlin
When installed correctly an offset flange is not a problem.
Marlin is offline   Reply With Quote
Old 12-04-2007, 07:38 PM   #3
There's a right and wrong way to install them?
Old 12-05-2007, 06:16 PM   #4
It's just like any other flange. Make sure it's just above the floor and properly attached.
Old 12-06-2007, 02:20 AM   #5
That one Guy's Avatar
Tricky though if you ever tried to run a 11/16' or 3/4" snake down one and catch the vent the right way.
That one Guy is offline   Reply With Quote
Old 12-06-2007, 06:54 PM   #6
Journeyman Plumber
Ron The Plumber's Avatar
Cods will say if there allowed or not, here there against code.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-07-2007, 07:45 PM   #7
Really? I had no idea they were illegal in some places. Take Ron the Plumbers advice then and check.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Replace a PVC Toilet Flange bcdad Plumbing 4 12-06-2007 04:46 PM
Installing new toilet flange. helpless handyman Plumbing 7 11-16-2007 07:47 PM
Rusted toilet flange on PVC pipe wyoming777 Plumbing 15 11-09-2007 10:53 PM
Toilet Flange txbostont Plumbing 5 10-31-2007 12:01 PM
