Toilet Not Sitting Flush To Floor... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 06:33 PM   #1
Toilet Not sitting flush to floor...
Hey forum...First, before my new renovations in my bathroom, the old toilet was flush to the floor and the floor tiles that it was seated on were thinner than the new tiles we just put down. The toilet flange sits 5/8ths of an inch above the floor. The old toilet never rocked or leaked and sat flush. We bought a new toilet with the seat sitting higher than the old one. Easier to get up off of. The toilet does not sit flush. I never payed any attention if the old ring had a horn on the wax seal on the old toilet. Would that make a difference? Should I try a wax seal without the horn? I know everyone says the flange should be flush with floor. I am on a cement slab. Cast iron pipe and flange. I just cannot believe the new toilet is doing this. Sorry no pics..Please, any advice would really help. Thank you for your time...Ray...
fatboy1729 is offline   Reply With Quote
Old 03-16-2013, 06:37 PM   #2
DIY staff
Rewards Points: 7,174
Try the toilet without a wax ring---if it sits right --use a simple all wax ring----let me know---
fatboy1729 (03-17-2013)
Old 03-16-2013, 06:44 PM   #3
Rewards Points: 1,532
Test the toilet for steadiness before installing the wax ring.
The toilet must not actually touch the flange.
Use shims around the outside edge of the toilet if needed.
If the toilet rocks after final installation then that wax ring has become deformed and you will need a new one when you get things fixed again.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
fatboy1729 (03-17-2013), oh'mike (03-16-2013)
Old 03-17-2013, 06:18 AM   #4
I just had the same problem the other day. Had new bowl and old bowl same make and just a newer version by 8 years and ill be damned the new toilet had less room from outlet to flange. The old bowl sat right on tile new one up about 3/8" old plumber raised flange up with plywood ring under and had to chisel out some to drop flange so new toilet would sit flat.pain in a-- but worked fine just saying .
joes plumbing is offline   Reply With Quote
The Following User Says Thank You to joes plumbing For This Useful Post:
Old 03-17-2013, 08:36 PM   #5
Hi OhMike, Tried it and it still did not sit flush. I was about to cut the flange to make it fit then someone told me to try a different toilet to see if the new one would sit flush before cutting down the flange. Tried the new one and it fit like a glove. The new one had more space under it than the old one. Thanks again...Ray...
The Following User Says Thank You to fatboy1729 For This Useful Post:
oh'mike (03-18-2013)
Old 03-17-2013, 09:09 PM   #6
Roofmaster
Rewards Points: 2,210
What make was the toilet that did not have proper space so I never buy one. Where was it made? Let me guess, it starts with C, and ends with A? Stick with USA made plumbing fixtures.
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Toilet rocks on tile floor Richo Plumbing 18 11-19-2012 12:04 PM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 05:33 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
