Toilet Is Not Set Straight - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2009, 06:46 AM   #1
toilet is not set straight
Just had the tile done and the toilet was not set straight to the wall. Can it be adjusted without having to totally reinstall it with a new ring? Probably off by an inch or so.
Additional issue - the tank is not level (high on the right). I moved it a bit and water leaked out. Is it as simple as draining it and wiggling it straight? Are there any seals to be concerned about when making the adjustment?
molsendiy is offline   Reply With Quote
Old 02-08-2009, 08:09 AM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
Unless the closet flange was set very poorly, you should be able to loosen the commode bolts and twist it enough to square it up, then retighten your bolts.
Man of many hats
wrangler is offline   Reply With Quote
Old 02-08-2009, 08:48 AM   #3
Is it a brass flange? ABS flange? one of those new expanding types? If it is a brass flange and ajustment would be very easy. If it is abs and glued in place that would require substantial work. If its one of those new types with the rubber piece that goes in the pipe, That would be an easy ajustment.
scotty123 is offline   Reply With Quote
Old 02-08-2009, 09:16 AM   #4
Rewards Points: 190
How much to tighten the bolts?
Similar problem with a toilet I installed. It started out straight but shifted because I was afraid to tighten the bolts too much and crack the base. I probably only gave it a quarter turn with a wrench after the bolts were hand tight. How easy is it to crack the base? Can I safely tighten it up some more after I straighten it?
zircon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
