Toilet Not Securely Fastened - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-14-2009, 03:03 PM   #1
sweaty
Rewards Points: 270
In my rental house, I have a bathroom in the basement and the toilet moves somewhat along the floor. What do I need to do to fix this? Any danger of sewer gases coming up?
sweaty is offline   Reply With Quote
Old 01-14-2009, 03:35 PM   #2
bradnailer's Avatar
First you'll need to make sure the closet flange is secured to the floor. Since you are probably on a slab, you may need to anchor the flange to the floor by drilling the concrete floor and setting anchors. Once you get the closet flange secure, install a new wax ring and secure the toilet with closet flange bolts.
If the toilet doesn't leak when you flush it, there's a chance you aren't getting any sewer gasses in the room, but unless you fix it, it will only get worse.
bradnailer is offline   Reply With Quote
Old 01-15-2009, 10:00 AM   #3
Not sure how much "somewhat" is, but it should not move at all. Check the bolts on the bowl base to insure they are tight. Since it has been moving, I would suggest pulling the toilet up and replacing the wax seal. At this time you can make sure the flange is not broken or able to move.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaky toilet flange? ScottieBaseball Plumbing 5 01-04-2009 12:57 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
why one toilet backs up and other does not Richmarti12 Plumbing 2 03-16-2008 02:22 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
