Toilet Not Secure To Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2009, 08:27 AM   #1
Toilet Not Secure to Floor
Hello,
My toilet is not secured to the floor meaning that when someone sits on it, it gets pushed to the floor and when they stand up the back of the toilet hits the wall instead of the toilet not moving at all. What's up with this and how do I get it fixed?
Thanks!
CommMajor101 is offline   Reply With Quote
Old 07-12-2009, 09:01 AM   #2
There should be a bolt on each side of the bowl at the floor. Check to see if the nuts are tight or if the bolts are broken. Try tightening the nuts first. Don't "crank" on them, just snug them up. If one or both of the bolts are broken, you will need to lift the toilet, replace the wax seal and replace the bolts.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 07-12-2009, 03:01 PM   #3
thanks! i'll give that a shot and post back what happens
Old 07-12-2009, 05:12 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Another thing it could be is the toilet flange not being secured to the floor. If this is the case it wont matter if the toilet bolts are tight or not. Any play in the piping will be evidenced at the toilet itself.
JDC is offline   Reply With Quote
Old 07-12-2009, 05:21 PM   #5
thanks JDC - I don't know what any of that means - haha. What's flange? What does "play with the piping" mean? What will be the evidence at the toilet? Thanks again!
Old 07-12-2009, 05:33 PM   #6
The drain pipe that goes to your toilet comes up through the floor and ends at the closet flange. This flange has holes in it to connect to the floor to prevent movement, which can ruin the wax seal or possibly break the pipe. In the link below, notice that the flange has elongated holes and round holes. The round holes are for securing to the floor. The elongated holes are what the closet bolt hook into. The closet bolts have oval shaped heads on them that lock onto the flange and hold the toillet steady. Just click on the link below.
http://plumbing.hardwarestore.com/51...t-flanges.aspx
Old 07-12-2009, 09:06 PM   #7
ok so the bolts seem to be tight, so i guess it's the flange and other things you mentioned. who do i call to come a fix it? i wish i could do it myself, but I can't lift a toilet, so a plumber or someone else? thanks for your help!
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
Rotted floor boards. How do I fix THIS??? gshock Building & Construction 4 08-14-2007 06:59 PM
2nd Floor toilet ffgus Plumbing 4 12-01-2006 07:55 AM
