Toilet Not Getting Water To Fill Up - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2011, 03:50 PM   #1
A toilet upstairs in my house was slowly leaking down and filling up with water. The flapper appears tight and not the cause. I turned off the water supply to drain the tank in preparation to replace the fill valve, replaced the fill valve with no issues, but the water supply will not deliver water since. Any advice?
mdlab is offline   Reply With Quote
Old 08-27-2011, 03:52 PM   #2
DIY staff
Rewards Points: 7,174
Have you replaced the shut off valve yet? Sounds like it broke in the 'off' position.
Old 08-27-2011, 03:59 PM   #3
No, I haven't...I'll start looking for good directions on the forum and internet. In your opinion, easy enough task or let a pro do it?
Old 08-27-2011, 05:35 PM   #4
DIY staff
Need more infro--Is house piped in copper?
If so is the valve soldered on or held with a nut?
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 01:17 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Hot Water Toilet GeauxCajuns82 Plumbing 1 10-10-2008 09:21 PM
