Toilet Is Not Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2011, 02:01 PM   #1
Toilet is not Flushing
New tenant just called on the first day of move-in that both toilets in the house are not flushing. Water do not go down on the toilets. We turned off water with the city for 8 months prior to today so today's the first day that the toilets have been flushed (or attempted to be flushed) in 8 months. They were not clogged or backed up before we moved 8 months ago.
Any idea why?
Thanks.
lydiainflorida is offline   Reply With Quote
Old 08-01-2011, 02:14 PM   #2
Rewards Points: 150
My friend had tenants that poured cement down the toilets when they moved out. Could that have happened?
Broughton is offline   Reply With Quote
Old 08-01-2011, 02:16 PM   #3
No..we were the last people living there before today.
Old 08-01-2011, 03:50 PM   #4
Rewards Points: 150
The chain on the flush lever is connected to the flapper inside the tank and the water is turned on and there is water in the tank. When you flush what happens?
josall is offline   Reply With Quote
Old 08-01-2011, 04:20 PM   #5
Tenant says water goes up in the toilet and overflows but does not flush (does not go down).
A plumber came earlier and wanted to charge $150 per toilet to repair the bottom part and replace flapper inside the tank. I just want to make sure that he is being honest about the situation since we are not there to look at it ourselves.
Old 08-01-2011, 04:40 PM   #6
Lightfoot's Avatar
Rewards Points: 272
Not sure what the "bottom part" of the toilet is, but flappers are about 3 bucks.
Lightfoot is offline   Reply With Quote
Old 08-01-2011, 04:45 PM   #7
I think it's the gasket at the bottom of the toilet.
Old 08-01-2011, 07:12 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 684
Did you try a plunger or toilet auger?
Get a better description from your plumber. I don't see any reason to repair a toilet when it's backed up. A flapper lets water into the toilet- a blockage keeps it from going out.
You say there's 2 toilets? Are they back to back or on a common drain line?
Toilet not flushing away contents effectively.... conbutts Plumbing 6 05-24-2011 10:27 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 04:01 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 03:00 PM
