Toilet Is Not Flush To Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2012, 06:10 PM   #16
DIY staff
Rewards Points: 7,174
Funnel on the wax ring is not needed---Sounds like you have a 3 inch pipe--with a 3 inch inside glued flange----
Is the flange glued inside the pipe or outside?
ben's plumbing (08-11-2012)
Old 08-11-2012, 06:59 PM   #17
Rewards Points: 77
Flange is inside the pipe.
I went out and bought a wax ring without a funnel. I also took a closer look at the toilet and pipe junction. I believe your solution (wax ring without funnel) will do the trick. anymore pointers before I proceed?
shorteared is offline   Reply With Quote
Old 08-11-2012, 07:30 PM   #18
Rewards Points: 582
remove old wax ring take a dry run to see if commode will set on floor...if it does install wax ring ..without horn....that should work...bensr
Old 08-11-2012, 07:33 PM   #19
DIY staff
To others reading this---never use unside glued flanges on a 3" pipe----the trouble this member is have right now is the result---
ben's plumbing (08-12-2012)
Old 08-11-2012, 10:53 PM   #20
Rewards Points: 77
All is well. Thank you for the advice. Toilet is flush and working well!
The Following 2 Users Say Thank You to shorteared For This Useful Post:
ben's plumbing (08-12-2012), oh'mike (08-12-2012)
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Toilet rocks on tile floor Richo Plumbing 18 11-19-2012 12:04 PM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 05:33 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
