Toilet Needs Fixing - Have Parts But What Goes Where? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2013, 07:06 PM   #1
Toilet needs fixing - Have parts but what goes where?
I need to fix the toilet and I have the parts for it. My problem is I don't know what part goes where. A friend gave me this set of parts in a plastic bag but no instructions were included. I can't see underneath the toilet it's a European type I think (Incepa). I have never done this before but I'm sure I could do it if someone could just tell me where these parts go - the 4 loose ones.. inside the tank or outside... which one first...... thanks!
Girly_girl is offline   Reply With Quote
Old 03-16-2013, 07:13 PM   #2
Rewards Points: 2,038
The big nut with the wings is incase your replacing the water connection. The big flat on one side nut is what actually holds the flow valve in the tank. The two rubber things are for different water supply connections.
Old 03-16-2013, 07:15 PM   #3
http://plumbing.about.com/od/toilets...Fill-Valve.htm
Old 03-16-2013, 08:11 PM   #4
Rewards Points: 14,000
That's a really cheap flush valve I would not even bother installing it.
Get yourself a new Fluid Master for about $10.00.
Old 03-16-2013, 08:59 PM   #5
Roofmaster
Rewards Points: 2,210
The flat one with the four holes threads up onto the flush valve after you stick it through the hole inside the tank.
If you buy a stainless braided toilet supply, you don't need the others. If your flush valve is old enough to need to be replaced, do yourself a favor and replace the supply tube with a stainless braided one.
I assume you know that the float ball is needed on the end of the brass rod, and the rubber tube adjacent to the rod clips to the inside of the overflow tube with a little S clip. Right?
The Following User Says Thank You to jagans For This Useful Post:
Girly_girl (03-16-2013)
Old 03-16-2013, 11:22 PM   #6
Well the flush valve broke and is no longer holding the float ball so I have to tighten and untighten the screw every time.. or the water runs constantly and it's driving me crazy!
So you say a stainless braided supply tube is better OK noted! I want to change to valve anyway so may as well do that at the same time right? There's one already (with a screw in the middle) but it leaks when I open it up so I will change it with another type (1/4 turn) I find those more reliable. The old one I put in 14 years ago already.
Not quite sure if I need the S clip since this model has a hole to put the tube in. I'll try to tackle this project this week sometime.
Sorry if I don't have the right terms but you got it right?
THANK YOU! Girly_girl
help me finish fixing my running toilet MLMIB Plumbing 1 09-04-2012 09:01 PM
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
fixing toilet angle valve leak pro_DIYer Plumbing 7 07-11-2009 09:11 PM
Rebuilding 3 Gallon toilet can I still get parts? twilightcall Plumbing 1 06-14-2008 12:11 PM
