Old 06-28-2009, 03:15 PM   #1
Question
Toilet making a whistle sound
Once we flush our toilet, and the tank begins to refill, it makes a funny whistleing sound. We had the toilet installed about two years ago and never had any problem. There also does not seem to be any issue with the tank filling just the noise.
I am wondering if there is some trapped air somewhere, but don't really know where to begin.
Any help would be much appreciated!
cjppage is offline   Reply With Quote
Old 06-28-2009, 04:29 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
The toilet water inlet valve in the tank is failing, and you just need to replace it. Get a Fluidmaster 400a for only about $5-$6 bucks, follow the easy illustrated directions that come with it, and your problem should be solved.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-29-2009, 09:10 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Well heck....take the whistling at your naked bum as a compliment! LoL
Seriously though, Mike is correct. You need a new fill valve and the Fluidmaster 400A is the way to go.
JDC is offline   Reply With Quote
Tags
bathroom, flush valve, noise, toilet
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Furnace is making a whistling/humming sound JayBird HVAC 7 01-26-2008 09:35 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 05:33 PM
