Toilet Making Pipes Vibrate? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2012, 12:44 PM   #1
Toilet making pipes vibrate?
Hi, all. Need some help. I think there's a simple solution but I just don't know it. Please note I am a new homeowner and don't know the simplest of things about home repair but I am learning as I go.
I just had all my pipes (but not drains) redone in my house.
I am still having a problem with the upstairs toilet. I thought it was because of the pipes, but it must be the toilet. There are no issues with the sink.
2 - 3 minutes after I flush, after the tank is filled up the floor and pipes in the floor/wall vibrate. It's loud.
I played around w/ it last night and while it's vibrating if I lift the float arm, the vibrating stops. Based on this information, what part do I need to replace inside the toilet to make the vibrating stop?
Thanks.
BeeTee is offline   Reply With Quote
Old 01-26-2012, 12:47 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by BeeTee View Post
I just had all my pipes redone in my house. <--WHY?
What problem were you having before?
Was this the reason you had all the pipes replaced?
Does opening and closing ANY OTHER faucet in the house have this effect?
Old 01-26-2012, 01:06 PM   #3
No, it doesn't. Before I had all the pipes redone (they were mixed galvanized, pvc and copper, now all copper), I had one guy tell me it was an air pocket and to open all the faucets and let them run then shut them off after a while starting furthest from the toilet (didn't work) or it was a rust pocket in the pipes (now I have new pipes).
It was also suggested it was the drain but considering it stops when I lift the arm, I think it's the toilet, as someone else suggested to me.
Old 01-26-2012, 01:10 PM   #4
MarginallyQualified
...I had one guy tell me it was an air pocket and to open all the faucets...
How about both are right?
Or the first guy's instructions didn't go quite far enough?
(the toilet fill valve has crud in it)
Try the second part of this method first...
Originally Posted by AirHammerFixologist
Shut off main water inlet valve to the house.
Turn on all water outlet valves inside and outside the house,
then flush all toilets.
Allow outlets to drain and pipes to fill with air.
Then turn on main water inlet valve and fill and shut off inside and outside outlet valves.
Remove toilet valve caps by rotating 1/8 turn counterclockwise.
(on basic Fluidmaster 400A: lift arm first)
Hold a container over the uncapped valve and turn water supply on and off a few times to clear debris.
Replace top by engaging lugs and rotating 1/8 turn clockwise.
Old 01-26-2012, 02:56 PM   #5
Lightfoot's Avatar
Rewards Points: 272
sounds like the fill valve in the turlet. if it's a fluidmaster brand fill valve, just replacing the little rubber disc in the top of the unit will likely fix it. no tools required, about a 5 minute job, and cost about 2 bucks. flush the line out while you're at it by putting a cup over the top of the fill valve (while it's apart) and turning it on for a few seconds.
Lightfoot is offline   Reply With Quote
Old 01-26-2012, 07:35 PM   #6
Rewards Points: 582
just replace ball cock assy with fluidmaster 400a ...if pipes still rattle call back company that installed your copper ..needs straped..
Old 01-27-2012, 08:15 AM   #7
Thanks for all the info, you all gave me some good tips.
End result, bent the float arm and that stopped the problem. I didn't think of this myself, of course. Boyfriend did it.
Old 01-27-2012, 08:26 AM   #8
DIY staff
Rewards Points: 7,174
That's an older flush valve---a new one is only about $10--and is simple to install---if the problem happens again--just change the guts--
Old 01-27-2012, 08:33 AM   #9
It is an old toilet! I will change it out at some point. Figured I'd try the easy fix first. TY!
Old 01-27-2012, 08:45 AM   #10
MarginallyQualified
do NOT replace the toilet!
just the fill valve (and flapper)
Fluidmaster 400:
Old 01-27-2012, 08:53 AM   #11
I meant the inards. I'm a cheapo and won't replace anything that works. Thanks for the pic.
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Hot water pipes (closed system) vibrate very loudly. Peety HVAC 8 02-07-2010 09:53 AM
Toilet Flushing Causes Noisy Cold Water Pipes mrduck10 Plumbing 3 02-03-2010 06:10 AM
Stream Radiator - Pipes and Radiators are making noises gforce HVAC 6 01-02-2008 09:58 AM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
