Toilet Making Foghorn/jackhammer Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 10:02 PM   #1
toilet making foghorn/jackhammer noise
After flushing the toilet and the water tank completely fills up again, there is a loud and persistent foghorn/jackhammer noise that seems to shake the wall. The only way to get the noise to stop is to turn the water valve below the toliet (on the wall) to the total "off" position. Is this a serious problem/costly repair, or is there an inexpensive fix to stop this annoying problem?
Dani is offline   Reply With Quote
Old 01-19-2011, 10:25 PM   #2
Lightfoot's Avatar
Rewards Points: 272
www.fluidmaster.com
model 400a toilet fill valve.
available at Lowes, HD, and Ace hdwe.
only around 10-12 bucks.
very easy to install, and pretty much maintenance free. just replace the rubber fill valve seal every few years.
It's the only one i'll buy.
Lightfoot is offline   Reply With Quote
Old 01-20-2011, 06:20 AM   #3
What he said. The shutoff valve is vibrating. Fluidmaster, cheap, lasts a long time, generally worry free.
Old 05-23-2011, 03:53 AM   #4
Rewards Points: 12
Mine has been doing this for about a year. I was on my computer last night and my computer keyboard vibrated (from the cistern vibration!).
I changed the washer but it seemed to have made it worse. I need to fix this as I'm scared of flushing the toilet at night and waking up the family.
enragedpurple is offline   Reply With Quote
Old 05-23-2011, 06:51 AM   #5
It could also be a loose washer in the toilet supply shutoff valve. Or a washer type shutoff valve not fully open(not an issue with ball type valves). Check the house water pressure. Should be about 45-60lbs. Inexpensive pressure gauge available at home, hardware stores.
Old 05-23-2011, 10:23 AM   #6
Rewards Points: 12
I don't think it's the pressure to the house because the other toilets in the house don't make a sound. I'll go have a look at the shut off valve now.
Cheers Bill (you're not JUST Bill, you could be Bill the lifesaver )
Dripping noise from toilet drain redpoint5 Plumbing 18 10-30-2013 06:23 PM
Trane 1100 XE- Outside unit making humming noise Momof2 HVAC 0 09-03-2009 11:25 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
weird pipe noise after toilet flush bourbonboy Plumbing 1 11-30-2007 04:18 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
