Toilet Leveling - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 09:01 PM   #1
Rewards Points: 337
Toilet leveling
I am about to install the toilet, couple questions:
The tile was installed close to level, the toilet needs 1/8" shim at the rear to level it front to back. When I do this it's rock solid front to back and side to side. The toilet is out of level side to side by 1/8". Is it really necessary to shim the side to a perfect level? I was thinking it would be more stable to have more of the toilet bowl contacting the floor and having it 1/8" out of level than it would be to have it resting on two shim to achieve a perfect level?
Also, I will need two was rings as the flange is about 3/4" below the tile, I planned on placing a thick ring with the plastic flange in in on to the toilet flang and a reg wax ring on the bottom of the bowl and then seating the bowl.
Anything wrong with my execution
titan7 is offline   Reply With Quote
Old 05-04-2012, 09:22 PM   #2
Rewards Points: 582
your fine on being out of level...Iam not liking the flange 3/4" below finish floor..your asking for trouble.... is this on 1st or 2nd floor???
Old 05-04-2012, 09:27 PM   #3
Rewards Points: 337
It's one the 1st floor. The closet flange is in the concrete. I used two wax ring for the past 10 years when the old tile was there. What other option is there? The plumbers here in soca recommend the same? The only other option is the plastic spacers sandwiched together.
Old 05-04-2012, 09:30 PM   #4
Rewards Points: 768
You can buy a flange extender. I have one and it works A LOT better than using two wax rings. Shims are somewhat normal. Just make sure you caulk around the base of the toilet and that will settle any movement that is happening now.
cibula11 is offline   Reply With Quote
Old 05-04-2012, 10:16 PM   #5
Rewards Points: 636
something like this link just need to get correct size, they also sell toilet shims "little plastic shims" out of level toilet will work
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is online now   Reply With Quote
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
How to handle toilet flange when leveling floor Homerepairguy Plumbing 11 12-08-2010 12:01 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
