Toilet Leaking Into Walls - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2011, 12:30 PM   #1
Question
Toilet leaking into walls
We use the blue cleaner in our toilet, and notice blue under one of the bolts. The walls in the corners of this area are showing blue, and are sometimes damp as well. One tile came off, and the metal corner bead on the sheetrock is rusting. Is it possible the wax ring has deteriorated, allowing some seapage under the tile and into the studs. We are on a slab. I plan to remove the toilet to see what I can find out, but would appreciate any ideas beforehand.
sydni2009 is offline   Reply With Quote
Old 01-26-2011, 12:46 PM   #2
Owner
LateralConcepts's Avatar
Yes, you need to remove the toilet, inspect the flange, and re-set it with a new wax ring and bolts. Going forward, don't use tank type toilet bowl cleaners. Blue or not, the chemicals deteriorate the plastic components inside the tank. The blue stuff can also badly stain tile, etc.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
sydni2009 (01-26-2011)
Old 01-26-2011, 01:38 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
When you remove the toilet, check that the floor is flat and level. If the floor is not flat, the toilet can rock and break the wax ring seal no matter how many times you redo the job. Concrete slab floors especially, can have high points that allow the bowl to rock. There are plastic shims made to level toilet bowls that you can use to prevent rocking.
If you have a wood floor, then also verify that it is not rotted out from the continuous moisture.
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
Toilet leaking air sound AngeloUCF Plumbing 14 07-13-2015 08:31 PM
Toilet leaking after reinstall phil74501 Plumbing 7 10-27-2010 11:12 PM
Leaking toilet/bidet- big problem Trailman Plumbing 11 09-28-2010 04:41 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
