Toilet Leaking From Bolts - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2010, 12:20 AM   #1
Toilet leaking from bolts
I just walked into a bathroom and hallway full of water. The bowl was empty when I walked in. When I flushed the toilet again, the bowl filled and water did not want to go down, meanwhile I noticed a trickle of water flowing from the bolts. Eventually the water did go down, I shut off the water at the angle stop. Not sure where to start, any suggestions.
plumbingissues is offline   Reply With Quote
Old 11-25-2010, 02:37 AM   #2
Thumbs down
toilet may be pluged thats why it dont flush down snake it as for the dripping shut the water and replace the washer in the tank there are two bolts that go thru the tank to under side of toilet but make sure not to over tighten them as it will break it is fragile if you still need help frog1973@hotmail.com
steve1973 is offline   Reply With Quote
Old 11-25-2010, 05:36 AM   #3
Rewards Points: 40
Was the bowl totally empty or a normal water level?Which bolts are leaking?The tank bolts steve mentioned or the flange (floor) bolts?
daveb1 is online now   Reply With Quote
Old 11-25-2010, 10:06 AM   #4
The only reasons the bowl would be empyt is a cracked bowl, or clogghed vent pipe that allowed the bowl water to be sucked out. The main discharge line is clogged and needs to be augered out. The back-up caused the wax seal to break, so you will need a replacement.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-25-2010, 10:08 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,... My guess is the drain pipe is clogged up, 'n the wax ring is compromised...
If you're not up to pulling the toliet, snaking the drain, then putting it back together,...
Call a Plumber...
Bondo is online now   Reply With Quote
Old 11-26-2010, 09:08 PM   #6
Update...
Thanks all for the information.
I just noticed that this same toilet bowl is now full of poop. No one has used this toilet, this is a downstairs toilet, the rest of the toilets are upstairs, is this the result of the toilets upstairs not draining correctly through and out of the house?
Old 11-26-2010, 09:12 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
sounds like the line somewhere after this toilet is plugged and when you use the upstairs toilet, it backflows into this toilet.
Time to get, most likely, the main line augured, or if damaged, repaired.
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 10:02 AM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Leaking tank-to-bowl bolts on toilet MI-Roger Plumbing 8 10-18-2009 08:29 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
