Toilet Leaking From The Base - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2011, 08:54 AM   #1
Toilet leaking from the base
Total newbie here so reply like Im a 5th grader. New house for me built in '87 and upstairs toilet shows a small trickle sometimes from its base. Removed the toilet entirely and shows rotten sub floor w/ mold thru both layers of thin plywood subfloor.I only pulled a small piece of top ply floor from behind where the toilet was and i can see the second layer of ply also has surface mold so I stoped and came here for advice on what to do next. Please advise and thanks in advance.
pieman is offline   Reply With Quote
Old 01-26-2011, 09:12 AM   #2
I will obviously be getting a professional for the remodle of this 10x6 bathroom so Im here looking for an education so I dont get taken advantage of. Thanks in advance.
Old 01-26-2011, 09:20 AM   #3
Rewards Points: 558
Well first you need to get at least (3) quotes on what needs to be done and have them spell it out on what they are going to do. Then get references on the jobs that they completed and follow up by calling and or going over to inspect their work. Make sure they are insured and they give you a time when the work will be completed.
epson is offline   Reply With Quote
Old 01-26-2011, 01:30 PM   #4
Homerepairguy's Avatar
Rewards Points: 998
+1
Get everything in writing including that the plumber is licensed and is insured. If you hire a non-licensed plumber and anyone in his crew gets hurt on the job, they can sue you bigtime since you will be considered the employer. Happened to a homeowner who hired roofers to re-roof his home on a weekend. Guy fell off the roof and sued the homeowner and won $297,000.
Also do a web search on the Better Business Bureau for the company.
HRG
Homerepairguy is offline   Reply With Quote
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 10:02 AM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 08:03 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
