Toilet Leaking Air Sound - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2010, 01:37 PM   #1
Rewards Points: 27
Toilet leaking air sound
There is a toilet that sounds like it is leaking air constantly. It does not appear to affect flushing, but the water level in the bowl does change. The sound appears to come from around the fill valve in the tank, but I can't pinpoint it. Any suggestions before I replace the entire thing? I've never replaced anything aside from the flapper but I'm pretty handy. Also, the air leak will often smell of exhaust fumes, which worries me.
AngeloUCF is offline   Reply With Quote
Old 01-17-2010, 06:31 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
can you be more specific?
plummen is offline   Reply With Quote
Old 01-17-2010, 06:39 PM   #3
Rewards Points: 27
Sure, but I don't know what else you need to know
It sounds like an air leak coming from the tank and does not stop, it's constant. I don't know where to start looking for issues.
Old 01-17-2010, 07:09 PM   #4
plummen's Avatar
is it spraying water from fill valve that youre hearing? is it a ballcock or a fluidmaster valve?
Old 01-17-2010, 07:50 PM   #5
Rewards Points: 27
It's a fluidmaster 400A. I don't see any water spraying from anywhere. The sound does go away when I push the "float cup" down but of course because the water starts to flow. I'm not sure if I called it correctly, it's the larger cylindrical black piece in the below picture
Old 01-17-2010, 09:48 PM   #6
Rewards Points: 1,088
One of my toilets does spray water from the fill valve during fill after a flush.
With the toilet tank lid design, no water has leaked out and the toilet fills and works normally otherwise.
Thoughts?
Also, do you have a bias against fluidmaster valves?
handy man88 is offline   Reply With Quote
Old 01-17-2010, 11:28 PM   #7
plummen's Avatar
i love fluidmasters myself,easy to work on.sometimes you get some crud stuck in the little diaphragm under top cap.
1.shut water off to toilet
2.pry the plastic cap off fluid master,usually just pry out on front corners then pull backon cap till it comes off.
3.the little plastic piece underneath that lever connects to turns counter clockwise to come off,pull up on the little locking taps till they clear then twist.
4.pull the little black rubber out and clean it
5.reverse for assembly.MAKE SURE THE TABS ON THE WHITE PLASTIC PIECE LOCK IN WHEN YOU REINSTALL
6.hold your hand over top of cap when you turn water back on in case tabs didnt catch,ive learned this the hard way!
Old 01-18-2010, 01:20 AM   #8
willowgirl's Avatar
Hum, I would try 2 things myself that would be quick and you don't to take anything apart.
You said you just changed the flapper, if it wasn't doing it before, it may not be sitting right to make it seal. which would keep like a slow run and there would be air pulled some. Just either unhook the chain and push the flap down tight. ( I saw a plumber put dish soap once and that fixed the problem, helped it slid into place or something i guess ) (There are different flaps for different toilets. )
Or the pull rod/ or pull rod spring isn't moving up enough to stop the water flow. My toilets are a little different, but if you lift it easily ( if not lift, lower ) you will probably here the water stop. The ones I have a screw on top you adjust it. Or maybe it just a little rusted.
willowgirl is offline   Reply With Quote
Old 01-18-2010, 09:36 AM   #9
Household Handyman
Rewards Points: 1,408
I'm with "plummen" on this one. Those are reliable units, but one very small piece of grit under the diaphragm will cause a very small leak which may be what you hear. Follow his instructions and I'll bet this will help. Thanks, David
Old 01-18-2010, 07:47 PM   #10
Rewards Points: 1,574
Make sure water level in tank is no higher than the black line on the overflow tube. If so, it will continue to allow water in and that may be the sound you are hearing. To adjust, you adjust the black float with the spring clip so it is lower on the tower.
bob22 is offline   Reply With Quote
Old 01-18-2010, 10:52 PM   #11
Rewards Points: 27
Thanks everyone, I'll try that plummen.
Old 07-09-2015, 08:22 PM   #12
Rewards Points: 4
Plumbing issue
I have a commode that is flushing fine. I turned off the shut off valve. Flush. It didn't drain completely then refills to the brim of the big tube in middle and then sounds as if air is coming out continually. What do I need to do? I have to repair myself. No money!! Thanks
Dianekh2015 is offline   Reply With Quote
Old 07-09-2015, 08:35 PM   #13
If you shut off the supply valve and the toilet still fills, then you need to replace the supply valve.
Old 07-09-2015, 10:26 PM   #14
Rewards Points: 228
Original thread is over 5 years old. Start a new thread of your own for better results.
jmon is online now   Reply With Quote
Old 07-13-2015, 09:31 PM   #15
Rewards Points: 4
Air sound from commode
Had a plumber out today. He said the sound was from my pressure relief value. He replaced it. Now 5 hrs later the sound of air coming from my commode is still present. What do I need to check for now? He is coming back tomorrow after I called him and told him it isn't fixed. Help! Thanks
Gurgling sound coming from the base of the toilet YerDugliness Plumbing 1 12-22-2009 09:35 AM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
