Toilet Leaking After Reinstall - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 05:29 PM   #1
Toilet leaking after reinstall
I had to take the toilet out to tile the walls in my bathroom. I reinstalled it, with a new wax ring. Now I have a small leak in two places. It wasn't leaking before I know that much. I didn't put any calk around it. There wasn't any before I removed it. Any suggestions? Thanks
phil74501 is offline   Reply With Quote
Old 10-27-2010, 05:38 PM   #2
Rewards Points: 150
A small leak where?
braindead is offline   Reply With Quote
Old 10-27-2010, 06:01 PM   #3
From under the bottom near the floor.
Old 10-27-2010, 07:50 PM   #4
Rewards Points: 1,506
If you had to wiggle the toilet a lot to get it into position, you may have squished the wax ring too much in a few places and then it will leak.
If the wax ring was not thick (high) enough, it would not seal against the bottom of the toilet and the flange of the drain pipe.
Old 10-27-2010, 08:12 PM   #5
So try putting a bigger wax ring on?
Old 10-27-2010, 08:29 PM   #6
HVAC / Plumbing
.This is what I've been using for some time, instead of using wax ring. Anyone else tried them ?
kenmac is offline   Reply With Quote
Old 10-27-2010, 08:59 PM   #7
take it off and resinstall
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
Old 10-27-2010, 11:12 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 568
Nope, it looks expensive
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 08:03 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
