Toilet Leaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2011, 06:53 PM   #1
toilet leaking?
Okay, so I recently reset my toilet and everything seems to be fine. There doesn't appear to be any leaking in the bathroom or any sewage odor. Is there any other place water can leak to. I am a little paranoid for some reason.
johndoe3 is offline   Reply With Quote
Old 09-12-2011, 07:17 PM   #2
DIY staff
Rewards Points: 7,174
Water could leak under the floor covering, What kind of floor?
Slip a sheet of paper or strips of paper under the throne--(toilet to you surfs) and see if it comes out dry.
If so you are probable fine.
Old 09-13-2011, 06:49 AM   #3
If the flange was above the level of the finished floor, and you used a new wax seal, chances of a leak are slim. But as suggested above, it could leak under the floor material. Assuming there is a basement under or a finished ceiling under, it will be obvious if there is a leak.
Old 09-13-2011, 07:18 AM   #4
Plumb or Die!
Sounds like you did good. So like, chill!
plumber666 is offline   Reply With Quote
Old 09-13-2011, 05:09 PM   #5
couldn't seem to get any paper underneath the throne. The floor is vinyl tile and the flange is above the tile.
Old 09-13-2011, 09:06 PM   #6
DIY staff
You should be fine---with vinyl tile any leak should run out from under the toilet and get your socks wet.
Old 09-13-2011, 09:32 PM   #7
Rewards Points: 558
You can also put some food coloring in the tank and see where it comes out if any.
epson is offline   Reply With Quote
Old 09-13-2011, 09:35 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You mean to tell us you don't have a leak and that's why you are here?
Are ya kidding?
Go to bed and sleep on it.
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 08:03 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
