Toilet Leak Mystery - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-13-2012, 11:49 AM   #1
Question
Toilet Leak Mystery
I have a leak in my toilet tank, but the tank only drains/leaks to about an inch below the fill line when I turn off the water supply. There is no water outside the tank or bowl.
The water supply has been off for a couple days and the tank has not lost any additional water.
Any suggestions would be helpful and appreciated.
Thanks in advance.
jabba is offline   Reply With Quote
Old 05-13-2012, 12:33 PM   #2
Rewards Points: 150
If no water is on the floor or other surface, then the flapper is probaly leaking but so small of a leak it takes a full tank of water to make it leak. Put just one drop of food coloring in the tank, it wil verify a slow leak if the colored water shows up in the bowl.
Jeeps is offline   Reply With Quote
The Following User Says Thank You to Jeeps For This Useful Post:
jaydevries (05-13-2012)
Old 05-13-2012, 02:50 PM   #3
Thanks. I will try that and see what happens. I know to start at the flapper, but since the tank only drained about an inch I figured it might be something else.
Old 05-13-2012, 07:46 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
post a picture of the insides of that toilet
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-13-2012, 11:30 PM   #5
Here you go.
Toilet Leak Mystery-img00153-20120513-2358.jpg   Toilet Leak Mystery-img00154-20120513-2358.jpg   Toilet Leak Mystery-img00155-20120513-2358.jpg
Old 05-14-2012, 12:31 AM   #6
If the shut off under the tank doesn't hold or you can't turn it then turn off all the water to the house. Open a faucet after turning off the main shut off to relieve the pressure in the pipes.
Sacramento Commercial HVAC
JackWebber is offline   Reply With Quote
Old 05-14-2012, 12:35 AM   #7
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by jabba View Post
Here you go.
How far down is the white (refill) tubing going into the overflow tube?
Water will be siphoned out of the tank until the water level in the tank is even with the bottom of the white tubing.
If the white tubing is protruding far down into the overflow tube, set the white tubing using the clip so the end is close to the top of the overflow tube. If you want the water level in the tank high, almost to the top of the overflow tube, there are clips that have an angle adapter that hold the end of the white (refill) tubing even with the top of the overflow tube. This should resolve your problem.
(Image from lockeplumbing.com)
HRG
Homerepairguy is offline   Reply With Quote
The Following User Says Thank You to Homerepairguy For This Useful Post:
Jeeps (05-14-2012)
Old 05-14-2012, 09:18 AM   #8
Rewards Points: 2,176
homerepairguy
thanks for the info.
Startingover is offline   Reply With Quote
Old 05-14-2012, 10:46 AM   #9
homerepairguy,
i think that might have been it. i moved the tube and filled the tank and did not notice the water level lower this morning. i still have the water supply off, so i'll check it again when i get home from work before turning the supply back on.
thanks.
Old 05-14-2012, 09:35 PM   #10
Yep I think that was it! Water level is still holding.
Old 05-14-2012, 09:40 PM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
HRG
I wish you hadn't beaten me to this. I love finding these on people's houses. They are so shocked and don't really understand what i'm talking about.
Journeyman Plumber
Old 05-15-2012, 11:35 AM   #12
Rewards Points: 998
Glad you found your problem. Now more time for other "Honey do's" .
HRG
Old 05-15-2012, 11:59 AM   #13
Master Plumber
Javiles's Avatar
Rewards Points: 996
Here you go.
thats why we ask for pictures, that's a common problem with that valve.
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Leak at toilet feed pipe dunixi Plumbing 5 01-28-2012 06:08 PM
Floor damage from a 2nd floor bathroom toilet leak Tamber Plumbing 3 05-02-2011 11:10 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
