Toilet Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2010, 07:37 PM   #1
toilet leak
recently, tile was laid in bathroom. Workers did not replace or raise the toilet flange, but stacked a thin wax ring onto a long horn jumbo wax ring. That was several weeks ago. Yesterday, toilet was flushed and appeared to empty slowly. Toilet did not overflow, but a couple extra flushes had water pouring into first floor from above.
Before I pull the toilet, did the wax ring(s) blow out or is there a way the water in sewer pipe could back up between horn of wax ring and the flange wall, then down through subfloor to downstairs?
When I heard an obstruction in pipe clear, the toilet flushed without any visable leaks downstairs.....any ideas?
BriscoeB is offline   Reply With Quote
Old 08-18-2010, 08:04 PM   #2
Owner
LateralConcepts's Avatar
If it cleared, just reset it with a new double wax ring.
While you have it off the floor though make sure there's no standing water in the flange, and check the underside of the toilet for any leftover blockage, i.e. Q-Tips, makeup containers, toys, etc.
Sometimes you think it's clear but the obstruction just shifted and allowed it to flush. If not cleared though could back up again. Every once in a while if there's something substantial stuck in the trap of the toilet it's not retrievable and you just have to replace the toilet.
Also while you have it off the floor run a bunch of water down the flange with the supply line to make sure it's draining ok.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
BriscoeB (08-19-2010)
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 06:52 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 10:31 PM
Toilet problem - Leak in Pipe underneath jackbean Plumbing 7 05-28-2008 10:33 PM
