Old 01-20-2013, 08:45 AM   #1
Toilet Leak
We have a toilet that two days ago started dripping water. Please see the attached image. My BF fiddled with it couple times and every time it stopped leaking only to start again after a few hours. I need to fix it. I have never done any plumbing repair or for that matter any repair before. So, I will need noob level instructions of how to go about it, including what tools I will need. Can you help please?
Thanks!
septerr is offline   Reply With Quote
Old 01-20-2013, 09:09 AM   #2
Super Moderator
Toilet Leak
Is the leak from the flexible tube or does it come from the valve by the handle?
Wipe the suspect areas with tissue---that will tell where the actual water is coming from.
Most common place--the valve---fix---put a wrench on the cap nut (thing with the valve stem poking through it) --and tighten it up about 1/4 turn.
If the feed line is leaking---replace it with a new one----
septerr (01-21-2013)
Old 01-20-2013, 11:23 AM   #3
Toilet Leak
This is where the water is dripping from. Thanks for your tip of wiping with tissue and then looking.
Old 01-20-2013, 12:00 PM   #4
Toilet Leak
Replacing the hose between the tank and shutoff valve may fix it, or it could be the washer that seals between the fill valve and toilet tank.
I would first replace the hose. While it's off, see if there's any obvious damage or leaks around the fill valve.
stephen9666 is offline   Reply With Quote
The Following User Says Thank You to stephen9666 For This Useful Post:
Old 01-20-2013, 12:06 PM   #5
Toilet Leak
I would start where stephen is suggesting as well. That hose is supposed to be tightened hand tight. Still, you usually can't get them off with your hand. Use channel-lock pliers.
https://encrypted-tbn0.gstatic.com/i...kBwPvr7QFTFDFQ
When you get the new one, attach the part near the toilet with your hands. Attach the part near the wall with an adjustable wrench ("crescent wrench").
https://encrypted-tbn0.gstatic.com/i...mrnaVUL7F6w-vQ
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
Old 01-20-2013, 12:10 PM   #6
Toilet Leak
Thanks!! I looked againa nd it does look like it must be the hose. I needed the info on the tools, so thanks again!
Old 01-20-2013, 01:17 PM   #7
Toilet Leak
In case you don't know, make sure to shut off the stop valve before you disconnect the hose, or you'll be taking a cold, high-pressure shower.
Old 01-21-2013, 02:06 AM   #8
Toilet Leak
Replaced the hose. The dripping hasn't completely stopped but far less than before. Do we just need to tighten the hose?
Old 01-21-2013, 02:32 AM   #9
Toilet Leak
100% sure it's not the stem packing nut that's not leaking.
It needs to be only snuged up in most cases. Be very carefull when tightning, over tighten and it's trash.
Old 01-21-2013, 02:59 AM   #10
747
registered
747's Avatar
Toilet Leak
Well you got a new hose. Might replace the fluidmaster. Now everything has been fixed which could be the culprit. It could be the seal under the fluidmaster. Its only like 10 at homedepot for a new fluidmaster(The fill valve inside of tank)
747 is offline   Reply With Quote
Old 01-21-2013, 05:42 AM   #11
Toilet Leak
Wow, that's a funny looking flush valve^^^^. Sell many?
64pvolvo1800 is offline   Reply With Quote
Old 01-21-2013, 10:35 AM   #12
Toilet Leak
@747 I will try replacing the fluid master tonight and let you know.
Tags
leak repair
Toilet (Mansfield) Ghost Leak golddog Plumbing 6 10-25-2012 08:10 PM
toilet leak julay Plumbing 2 09-06-2012 01:58 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Wax Ring Replacment and Toilet Leak kennykenny Plumbing 4 11-27-2010 03:43 PM
Toilet valve into wall leak. 68MHJCs Plumbing 9 11-21-2008 07:52 PM
