Toilet Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-03-2011, 10:06 AM   #1
Toilet leak
My tenant is claiming that he was unaware of the bad flapper in his toilet that caused excessive water usage. I calculated that approximately 3,600 gallons a day (is that possible?) was wasted. My question is....Can that amount of water pass through a toilet and not be detectable either audibly or visibly?
Grego1 is offline   Reply With Quote
Old 12-03-2011, 10:32 AM   #2
Lightfoot's Avatar
Rewards Points: 272
3600 gallons a day?
he's either deaf or blind, or both.
Lightfoot is offline   Reply With Quote
Old 12-03-2011, 11:36 AM   #3
Civil Engineer
Rewards Points: 4,514
3600 gallons per day would be 150 gallons per hour, or 2.5 gallons per minute, which is the equivalent of a shower head at full flow. This is certainly possible if the flapper never dropped, i.e. it hung up, however your tenant would be unable to flush the toilet, and they probably would have noticed that. Of course, if there are several toilets in the apartment, and they never used the one in question, I suppose it is possible they would not have heard the water running.
Old 12-03-2011, 12:44 PM   #4
If the tenant is young and plays loud music, he would not hear it. This also causes hearing damage, so he might not be able to hear it with the music off.
Also if young, these people tend to be self-centered these days and could care less about anything which does not directly have an impact on them. So perhaps if you raise the rent or make the tenant start paying the water bill, then leaks would immediately be reported?
Billy_Bob is offline   Reply With Quote
Old 12-03-2011, 03:39 PM   #5
Tizzer's Avatar
Rewards Points: 452
How did you come up with this calculation? It seems highly over the top. The fill valve would constantly be running if the flapper leaked that much.
Tizzer is offline   Reply With Quote
Old 12-04-2011, 12:56 AM   #6
Rewards Points: 175
unless you flushed it 2250 times without knowing. you can always pick up a closet "toilet" rebuild kit at your local lowes/home depot.
plumbing is offline   Reply With Quote
Toilet Bowl Rim Leak Msnbcjunkie Plumbing 8 10-13-2011 02:31 PM
toilet leak BriscoeB Plumbing 1 08-18-2010 09:04 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
