Toilet Issues - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-14-2011, 12:37 AM   #1
Toilet issues
I have a toilet that is doing strange things. #1: if you push the flush lever down all the way, the flapper remains up and the toilet runs. You can't even jiggle the handle to get it to drop; you have to remove the lid and manually drop it into place. #2: With every flush, the toilet bowl fills and empties twice.
The flapper was replaced about a month ago.
Does anyone have any advice?
Hkarp79 is offline   Reply With Quote
Old 03-14-2011, 07:06 AM   #2
Toilet issues
Replace the flapper again, with the Fluidmaster adjustable flapper. It can be adjusted to let out just the right amount of water for a full flush. Cost, about $6.
Old 03-14-2011, 08:48 AM   #3
Rewards Points: 5,326
Toilet issues
You need to readjust the length of the chain between the handle and the flapper, it's too short. It's a trial and error procedure. You might need to work your way to the correct length. Too long and it won't stay up. Too short and it won't go down.
Ron
condensation issues - major toilet sweat wombosi HVAC 8 07-23-2010 01:42 PM
Issues with toilet re-install tripower Plumbing 11 06-02-2010 06:24 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Toilet spacing issues... KC10KEVIN Plumbing 4 05-09-2008 12:27 AM
