Old 10-05-2012, 01:36 AM   #1
Toilet issues
I'm curios why you can't use regular drain cleaners on your toilet?
Chriscomp is offline   Reply With Quote
Old 10-05-2012, 06:48 AM   #2
Toilet issues
Bad for the pipes, if you have a septic system it will kill the good bacterier that's breaking down the soilds, they almost never unplug a stopage.
It makes it unsafe for anyone having to open up the clean out or snaking the drain to really clean out what ever is stopping the flow.
Old 10-05-2012, 07:48 AM   #3
Toilet issues
alot of drain cleaners will remove the glazing off the surface making it rough then paper and solids get stuck...causing a clog.. and damaging the commode...ben sr.....don't use them...
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Sterling toilet, flapper issues dinosaur1 Plumbing 13 06-19-2011 08:25 PM
Toilet leaks? but not really? gunrock Plumbing 3 04-22-2010 06:20 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
