Old 01-14-2010, 03:12 PM   #1
Question
Toilet Issue - Flap Sticking to Ball
Hello all - Nice place you got here, tons of good information.
Every time i flush my toilet, the flap gets stuck on the ball and water will keep dumping down the toilet. We have to open it up and reach in to correct this every time.
Any recommendations for correcting this? I have the ball set fairly low to ensure that we don't use too much water every time we flush. The flap is a soft rubber type flap.
Could i weigh the flap down? Can I lube up the ball so the flap wont' stick?
Thanks in advance!
booyah is offline   Reply With Quote
Old 01-14-2010, 03:57 PM   #2
Household Handyman
How long has your toilet flush system been in this tank? Some of those older flappers would get sort of "rubbery" and stick to most anything. Personally, IMO, I would change out the old fashioned float ball system to one of the newer float systems. These newer systems are much more accurate as to water levels and the components last longer. And- -they are a DIY project. Thanks, David
Old 01-14-2010, 09:28 PM   #3
Thurman is right on. You can pick up one of these for about 10 bucks. It will solve your problem and outperform the old style ballcock.
SuperPlumberGuy is offline   Reply With Quote
Old 01-14-2010, 09:38 PM   #4
That's perfect. Thanks a lot guys. I've swapped out a flap or two before, so this shouldn't be too bad.
Thanks again!!!
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet running water leaking issue? mikehende Plumbing 16 06-01-2009 11:07 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
