Toilet Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2007, 01:23 AM   #1
Toilet Issue
Just moved into new house. When i flush my toilet it has a running sound like its trying to fill up. Ive found if i turn the valve off and back on it flows normal and fills up stopping the running noise. Im sure this is simple, but im learning.
Thanks in advance
Jerry
c4m4r0 is offline   Reply With Quote
Old 05-31-2007, 05:07 AM   #2
It sounds like you have a fluid master ball cock, 99% of the time its the diaphram that needs to be replaced , if its a 400 A its under the cap on top ,200 its at the base.
tzzzz216 is offline   Reply With Quote
Old 05-31-2007, 10:58 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
Or just replace it with a new one.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 05-31-2007, 11:18 AM   #4
A whole new toilet?? Is replacing whatever he just mentioned really not worth the hassle?
Old 05-31-2007, 08:12 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
A 400A is only $6 bucks or so, and comes with very simple illustrated installation directions. Easy.
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-31-2007, 11:23 PM   #6
No, just a new valve. The part that's inside the tank on the left side.
NateHanson is offline   Reply With Quote
Old 06-01-2007, 12:02 AM   #7
Thanks guys, ill pick one up tomorrow.
Now if someone would just help out on my other post
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
