Toilet Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2016, 07:51 PM   #1
Toilet issue
When i flush the toilet the water from the tank empties into the bowl but doesn't go down. If i don't hurry up and put the flapper down the toilet will overflow. I also noticed water is not coming from the siphon holes except one. Please help.
Ashmarie319 is offline   Reply With Quote
Old 03-22-2016, 08:03 PM   #2
Rewards Points: 320
Re: Toilet issue
What have you tried so far? Any problem with other drains? Did plunging help at all?
If not, maybe clog is further down line and may need snaking.
jmon is offline   Reply With Quote
Old 03-22-2016, 08:35 PM   #3
The water goes down slowly..im thinking the siphon holes need to be clean cause only 3 of them have water coming out of them
Old 03-22-2016, 08:37 PM   #4
I've snaked it and plunged it and i notice when it does go down the water level on the bowl is really low
Old 03-22-2016, 09:32 PM   #5
Rewards Points: 320
Re: Toilet issue
Originally Posted by Ashmarie319 View Post
I'm thinking the siphon holes need to be clean cause only 3 of them have water coming out of them
I agree. Depending on your water type (well, city) the rim jets can become clogged with sediment. Seen it before.
Heat up some white vinegar and pour it down the overflow tube and let it sit for awhile. Then use a coat hanger or proper sized L-shaped allen head wrench and poke through the rim jet hole and try to break up the sediment. Try that first and see if that helps. Just a suggestion.
Old 03-23-2016, 12:35 AM   #6
I shall try that, thanks
Old 03-23-2016, 01:12 AM   #7
Rewards Points: 1,692
Re: Toilet issue
If the toilet is near to overflowing level and not flushing there is a local down stream blockage. When attempting to correct with the plunger, for better water level control, place the plunger in the toilet and fill the toilet with a pail of water rather than using the flush lever. Maintain a water level near full while plunging as the water level elevation is to your advantage.
This procedure is for a localized blockage and not for such things as tree roots etc. farther down the line.
Old 03-23-2016, 08:17 AM   #8
Rewards Points: 1,668
Re: Toilet issue
Agree with Sr; hold off on the vinegar and get rid of the clog.
Do you have hard water by the way?
bob22 is offline   Reply With Quote
Old 03-23-2016, 08:55 AM   #9
Rewards Points: 320
Re: Toilet issue
Yes, also agree with senior and bob. Your clogg is further downstream. My advice was for the rim jets, but they are not the source of your toilet overflow problem.
If following seniors advice still doesn't work, best to pull the toilet and investigate. Pour a bucket of water down the drain quickly and see if it backs up. You can snake from there as well. While the toilet is pulled, check that as well for any obstructions. Only cost will be a new wax ring. If you can't diy, time to call a plumber.
Old 03-23-2016, 11:39 AM   #10
No i don't have hard water, i will try the bucket and i will get a better plunger because mine sucks.
The Following User Says Thank You to Ashmarie319 For This Useful Post:
jmon (03-23-2016)
Old 03-24-2016, 11:06 AM   #11
My toilet is flushing properly now!
jmon (03-24-2016)
Old 03-24-2016, 11:12 AM   #12
Rewards Points: 320
Re: Toilet issue
Glad you got it unclogged and everything is working fine again now. Great job ashmarie.
Old 03-24-2016, 11:16 AM   #13
Thanks, now i can do the vinegar for siphon holes. I took q-tips and dipped them in bleach and swabbed out the holes most of them are working and some are not so i think they might have mineral deposits in them.
Old 03-24-2016, 05:16 PM   #14
Re: Toilet issue
You'll be there until after retirement using vinegar. Get a strong acid.
Old 03-25-2016, 07:45 AM   #15
Rewards Points: 1,538
Re: Toilet issue
The level of water in the bowl after the flush is complete depends on a variety of factors including the starting level in the bowl, the amount of water used for the flush, how fast the water is poured in, to what degree the drain venting is obstructed, and to what degree the drain under the toilet is partly clogged. But, if you repeat the flush with all five factors the same, the ending level in the bowl should be the same.
Usually the tank refill process adds enough water to the bowl via the thin tube to the overflow channel so to leave the level somewhat above the minimum you saw.
Sel clogging toilet (no one used for weeks) Patrick DuBois General DIY Discussions 8 02-23-2014 06:11 PM
Toilet leakng issue ( American Standard/ Champion 4 flushing system Homerlion Plumbing 13 02-08-2014 05:31 PM
Toilet plumbing issue JohnnyLion82 Plumbing 9 09-26-2012 11:03 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 07:41 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
