Toilet Issue? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2011, 08:47 AM   #1
toilet issue?
Today when i woke up i used the toilet upstairs flushed, didn't hear the "flush" (which is an issue in and of itself but nothing major just didn't hold the lever down long enough) came downstairs to my office a few minutes later nature called again, went to the bathroom downstairs. as i was going, i heard what i can best describe as a "crashing whooshing" sound followed by sounds of water moving through the pipes from the upstairs toilet. when i finished i got up turned around to flush saw a "paint bubble" coming from the wall that was filled with water. first thing i did was "pop" the bubble and drain it. then i peeled the paint back to allow the area to dry. i went upstairs after that to investigate then saw a bunch of water on the floor (centering from the toilet) cleaned that up. my question now goes to how did this happen and what can i do to investigate if it is something "easy" for me to fix or if i need to hire a plumber to take care of it? one thing i found out as of typing this when my fiance went to the bathroom last night, she said that it clogged on her after using it. could it just be that without her telling me that piece of information before hand that the pressure from my flush on top of "the clog" caused it to push through the drain? any and all help / advice is welcome and thank you in advance.
cebadec is offline   Reply With Quote
Old 07-12-2011, 11:49 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A toilet has a built-in trap that can clog fairly easily with too much paper, etc. The water on the floor was caused by the bowl overflowing because of the clog. The "crashing whooshing" sound was the clog finally going down the drain. Sounds like the clog corrected itself, so you don't need a plumber or to do anything else about that one.
However, a toilet clog will happen again, and if I were you, I would get a toilet auger, which is made for unclogging toilet traps. Just ask at the store and they will show you how it works (crank handle, etc.).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-12-2011, 11:54 AM   #3
also don't let your fiance put tampons down the toilet.
Old 07-12-2011, 03:46 PM   #4
Long-Time DIYer
Ditto.
NOTHING goes into a toilet but toilet paper and normal human waste, and even toilet paper will clog the trap if too much is flushed at once. All non-biodegradable stuff, such as tampons, hair curlers, children's small toys, etc. will always clog up a toilet sooner or later.
Mike
Toilet wont drain chazlew Plumbing 11 02-27-2011 10:08 PM
New toilet base doesn't line-up to floor bolts wwsteel7 Plumbing 9 11-25-2010 10:02 AM
Issues with toilet re-install tripower Plumbing 11 06-02-2010 05:24 PM
Toilet install - 2 questions BataviaJim Plumbing 11 05-11-2009 01:53 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
