Toilet Installation On Raised Tile Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2013, 05:16 PM   #16
Bill Kearney
Rewards Points: 1,174
Yep, the inside kind depends on the pipe being cut low enough that the flange can rest on it. Cut it too low and you don't have enough to get a bite on. The outside kind sit around the pipe and are a bit more forgiving in how low the flange can sit. You'd still want it low enough to avoid there being a place for waste to collect, but it's easier to gauge this when you can SEE how much pipe needs to be removed. Either way the flange itself is what gets screwed to the floor. The toilet is only held down to the flange by the closet bolts.
Added sturdiness around the flange can't hurt. It's not so much the weigh bearing down that's the issue, it's the side-to-side flex. If the flange screws have something beefy below to bite into you've got much less chance of that, especially if/when the subfloor gets wet and starts to rot..
wkearney99 is offline   Reply With Quote
toilet install over new tile floor dbrew Plumbing 11 07-08-2014 08:34 AM
Ceramic Tile Floor Info Help RichardZ Tiling, ceramics, marble 36 07-26-2012 08:33 PM
Tile installation on raised modular home karenrobinson Tiling, ceramics, marble 2 07-04-2012 10:01 AM
Floor Installation - Porcelain Tile over VCT...Please help diyuser1999 Flooring 3 05-20-2012 07:48 PM
Toilet Flange Problem - New Tile Floor w/ Ditra qwkslvr Flooring 4 10-14-2009 10:04 PM
