Toilet Installation? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2007, 08:34 PM   #1
Toilet installation?
I just completed installation of the second toilet in my house. The first one, went as planned with no issues. The second is questionable. I have no leaks on the top side around the bowl or supply line. But upon flushing for the first time i had minimal leakage. The second and third flush produced no leak???? Has anyone else had this problem and should remove the toilet and check the wax gasket? Thanks in advance.
L.Akers
Raptors is offline   Reply With Quote
Old 11-27-2007, 08:43 PM   #2
The leak was in the basement.
Old 11-28-2007, 11:25 AM   #3
If the toilet is on the first floor and the leak is in the basement, I would say the seal is bad OR you have a crack in the piping. You can continue "test flushing" to see if possibly the seal has gotten pressed down all the way and sealed or spend a couple bucks and remove the toilet to check the piping and replace the seal. Good luck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-29-2007, 06:57 PM   #4
Send a message via AIM to Marlin
Where does the flange sit relative to the floor above, below, or level? What size wax ring did you use?
Marlin is offline   Reply With Quote
Old 11-29-2007, 09:59 PM   #5
I prefer the flange to be level with or sitting on the floor. Wax seals are pretty much standard unless you purchase an extra thick one. I use the ones with a plastic horn in them. Made by Kno-leak or Kant-leak.
Old 11-30-2007, 06:12 AM   #6
Level with or sitting on the floor is the norm. I've had to use three rings with horns due to low flanges before though, that's why I ask. Their are two main types of rings, those with a horn, and those without. The ones without are about half an inch, the ones with a horn are about an inch. The ones without a horn only get used when the flange is above the floor or to make one with a horn thicker to account for a low floor. The ones with a horn are used when the flange is level with or only slightly above the floor. Below the tile gets more than one ring.
toilet installation gushing sharisavage Plumbing 5 04-25-2011 08:05 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 02:34 AM
Toilet flange installation Jeekinz Plumbing 1 04-23-2007 05:15 PM
Toilet installation markymark Plumbing 3 08-13-2005 09:37 AM
