-   -   toilet install with 10" rough (http://www.diychatroom.com/f7/toilet-install-10-rough-138034/)
sbmfj 03-23-2012 09:36 PM
Hi,
I need to install a new toilet, so I measure the distance from the anchor bolts to the wall and got 11". So I figure I need a 10" rough toilet.
My question has to do with the 10" toilet, a guy at a plumbing supply store told me that the bowl of the toilet would be the same regardless of a 10, 12, 14 rough, the only difference is in the tank, it will either be thinner (for the 10") or fatter (for the 14").
The toilet was a Vortens, and when I check out the website (http://www.vortens.com/elements/downloads/3208-3464.pdf ) and the specs for the Vienna model, the spec sheet shows the back of the bowl and the tank seem to be as far back, kinda flush. So Im think how is a thinner tank gonna help, as the bowl will end up sticking out abit regardless.
How does a thinner tank and bowl work? Is that drawing wrong, and the bowl is shorter, and the tank would always "overhang it" and a 10" would just overhang less?
ben's plumbing 03-23-2012 09:55 PM
Originally Posted by sbmfj (Post 884081)
Hi,
alot of 10" rough in closets use thinner tanks...that drawing you are looking at is a 12" rough ..look at #to left of chart 10" has a different # which would be a different drawing....10" rough will work for you...ben
sbmfj 03-24-2012 08:28 AM
thanks Ben,
I agree with you, its just when I look at the drawing of the spec sheet, the end of the bowl and tank seem to be flush.
SO im assuming the 10" tank will have less overhang, and that the bowl doesnt extend as far back as the tank, correct assumption?
Are all 10" rough in like this, ie they use a smaller tank?
md2lgyk 03-24-2012 09:00 AM
No, all are not done with a thinner tank. On the toilets i put in my house, the position of the tank on the bowl is adjustable. It can be moved toward or away from the wall up to about 2 inches.
shazapple 03-24-2012 09:18 AM
Caroma toilets have an adjustable flange to allow for 10" rough in.
