Old 10-21-2006, 10:58 PM   #1
Smile
toilet hole Q - not to the sewer
I have a short question...you know the hole in the base of the toilet (not the one that goes to the sewer) but the one opposite that about 3/4" or one inch, when working properly I think it helps push the water down into the sewer pipe. Well, mine is block because no water comes out. I have tried pushing thin wire in there to see if I could unblock it but the wire gets stopped like something is blocking it. Is there a way to unblock that little hole??
Jumper55 is offline   Reply With Quote
Old 10-21-2006, 11:07 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
A small pocket knife to help break it up will work.
Ron The Plumber is offline   Reply With Quote
Sewer Pump: How to make do? austinbirdman Plumbing 2 05-04-2011 10:35 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 04:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 02:22 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 11:09 PM
